Image converter tool offline - file format requirements
The image converter tool is currently inoperable and the website will not load. What file type do I need to use? I could try to make it in GIMP if I could get the specifications.
Originally submitted via email support on 18 June 2023. Migrated to the forum for community visibility.
A temporarily hosted version of the Image converter is available at: Image Converter
For this version, .png works best - it’s the simplest format with no compression.
If you encounter issues with weird bytes being outputted and your sketch won’t compile, this can happen in Brave browser - try a different browser instead.
