I bought the Voltage & current sensor INA219 breakout and am trying to connect it to an ESP32 to measure voltage.
I connected everything according to the instructions and code.
When I connect the battery to measure it, the battery overheats and I get no results.
Code:
#include "INA219-SOLDERED.h"
INA219 ina;
void setup() {
Serial.begin(115200);
if (!ina.begin()) {
Serial.println("Failed to find INA219 chip");
while (1) { delay(10); }
ina.configure(INA219_RANGE_32V, INA219_GAIN_320MV, INA219_BUS_RES_12BIT, INA219_SHUNT_RES_12BIT_1S);
ina.calibrate(0.1, 2); // Rshunt = 0.1 ohm, Max expected current = 2A
Serial.println("INA219 Initialized and Configured");
void loop() {
float busVoltage = ina.readBusVoltage();
Serial.print("Bus Voltage: ");
Serial.print(busVoltage);
Serial.println(" V");
delay(6000);
Connections: d21 and d22 to 3.3V and GND
Log output:
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0030,len:1184
load: ,len:13260
load: ,len:3028
entry 0x400805e4
What am I doing wrong?
kupio sam Voltage & current sensor INA219 breakout i pokušavam ga spojit na esp32 da bih mjerio voltažu.
Sve sam spojio prema upustvima i kod.
Kad spojim bateriju da idem izmjerit pregrijava se baterija i nema rezultata.
Kod:
#include “INA219-SOLDERED.h”
INA219 ina;
void setup() {
if (!ina.begin()) {
Serial.println(“Failed to find INA219 chip”);
Serial.println(“INA219 Initialized and Configured”);
void loop() {
delay(6000);
d21 i d22 3.3v i gnd
log:
load: ,len:13260
load: ,len:3028
entry 0x400805e4
možete li mi pomoć sa što radim krivo?
Originally submitted via email support on 16 April 2024. Migrated to the forum for community visibility.
