Inkplate 10 battery and enclosure availability
I ordered an Inkplate 10 without the battery and enclosure. Can I order those separately? How difficult would it be to fit the enclosure on the board myself?
Originally submitted via email support on 7 September 2023. Migrated to the forum for community visibility.
Regarding the battery and enclosure:
The Inkplate 10 version with a battery comes equipped with a 3000mAh battery, which is currently unavailable. Alternative options:
  • 2100mAh battery: We can provide a 2100mAh battery, which will perform just as well as the 3000mAh version. The only difference lies in its dimensions, resulting in less space required in the enclosure.
  • 3000mAh battery from another supplier: You may consider ordering a 3000mAh battery with the exact dimensions from another supplier.
We do not sell the Inkplate enclosure separately, but we have 3D printable files for DIY casing available, which could assist you if you decide to print one yourself.
