Can I connect a 10000mAh 3.7V Li-ion battery to the Inkplate10 display? Does the built-in charger support it and is it safe to use with Inkplate?
Mogu li spojiti ovu bateriju: Li-Ion Battery 10000mAh 3.7V - Durable Power Source – Soldered Electronics
na Inkplate10 display?
Da li ugrađeni punjač podržava istu i da li je sigurno koristiti s inkplateom?
Hvala,
Lp!
Originally submitted via email support on 25 July 2025. Migrated to the forum for community visibility.
The mentioned battery is compatible and its connector matches the port on the Inkplate 10 device.
navedena baterija je kompatibilna i njezin konektor odgovara priključku na samom Inkplate 10 uređaju.
The battery arrived and everything works. I have an additional question: is there a way to get information about the remaining battery percentage and/or other battery information (such as whether it’s charging, voltage, current)?
Baterija je stigla, sve radi
Imam još dodatno pitanje, postoji li mogućnost dobiti info negdje o preostalom postotku baterije i/ili neke druge informacije o bateriji (tipa puni li se, voltaža, amperaža)?
Hvala!
It is possible to read the voltage currently on the battery using readBattery: Inkplate-Arduino-library/examples/Inkplate10/Advanced/Other/Inkplate10_Read_Battery_Voltage/Inkplate10_Read_Battery_Voltage.ino at master · SolderedElectronics/Inkplate-Arduino-library · GitHub
It is not possible to detect with 100% certainty whether the battery is charging or not, but when USB is connected, readBattery returns around 4.2, and then by detecting this value with some tolerance you can detect whether Inkplate is charging. This corresponds approximately to the voltage of a full battery, so a function that would check whether the battery is charging or not would return false positives for a short time.
Current cannot be read on Inkplate 10.
Check the documentation for other questions: Inkplate Documentation | Soldered Documentation
ovdje sam za tehničke upite
moguće je pročitati napon koji je trenutno na bateriji koristeći readBattery: Inkplate-Arduino-library/examples/Inkplate10/Advanced/Other/Inkplate10_Read_Battery_Voltage/Inkplate10_Read_Battery_Voltage.ino at master · SolderedElectronics/Inkplate-Arduino-library · GitHub
Nije moguće detektirati 100% deterministički puni li se baterija ili ne, ali kad se USB spoji, readBattery vraća oko 4.2, i onda se preko detektiranja te vrijenodsti s nekom tolerancijom može detektirati puni li se Inkplate. To odgovara približno naponu pune baterije tako da funkcija koja bi provjeravala puni li se baterija ili ne bi vraćala kratko vrijeme false positive.
Amperažu nije moguće pročitati na Inkplate 10.
Nadam se da info pomaže
Provjeri dokumentaciju za ostala pitanja: Inkplate Documentation | Soldered Documentation
Since I flashed ESPhome firmware, do you know how I could access battery information there?
Hvala ti na primjeru i trudu.
S obzirom da sam flashao
ESPhome firmware, znaš li možda kako bih tamo mogao pristupiti informacijama o bateriji?
Hvala,
Lp!
Here is a config snippet for ESPHome that allows you to do this:
time:
- platform: pcf85063
# repeated synchronization is not necessary unless the external RTC
# is much more accurate than the internal clock
update_interval: never
- platform: homeassistant
# instead try to synchronize via network repeatedly ...
on_time_sync:
then:
# ... and update the RTC when the synchronization was successful
- pcf85063.write_time:
pca6416a:
- id: pca6416a_hub
address: 0x20
# Primary expander for display control and additional I/O
- id: pca6416a_hub2
address: 0x21
# Secondary expander for additional I/O
switch:
- platform: gpio
pin:
pca6416a: pca6416a_hub
number: 9
sensor:
- platform: adc
attenuation: 12db
pin: 35
- platform: template
unit_of_measurement: "V"
accuracy_decimals: 3
lambda: |-
// Enable MOSFET to connect battery voltage divider
id(battery_read_mosfet).turn_on();
// Wait for voltage to stabilize
delay(5);
// Sample ADC value
float adc = id(battery_voltage).sample();
// Disable MOSFET to save power
id(battery_read_mosfet).turn_off();
return adc;
filters:
- multiply: 2 # Compensate for voltage divider (1:2 ratio)
display:
- platform: inkplate6
greyscale: true
partial_updating: false
model: inkplate_10
ckv_pin: 32
sph_pin: 33
gmod_pin:
number: 1
gpio0_enable_pin:
number: 8
oe_pin:
number: 0
spv_pin:
number: 2
powerup_pin:
number: 4
wakeup_pin:
number: 3
vcom_pin:
number: 5
We are working on improving and better documenting ESPHome support for Inkplate in our new official documentation.
Nema na čemu,
evo kolega mi je poslao snippet configa za ESPHome gdje se ovo može
time:
instead try to synchronize via network repeatedly …
on_time_sync:
then:
… and update the RTC when the synchronization was successful
pca6416a:
- id: pca6416a_hub
address: 0x20
- id: pca6416a_hub2
address: 0x21
switch:
- platform: gpio
pin:
number: 9
sensor:
- platform: adc
attenuation: 12db
pin: 35
unit_of_measurement: “V”
lambda: |-
delay(5);
// Sample ADC value
return adc;
filters:
display:
greyscale: true
model: inkplate_10
ckv_pin: 32
sph_pin: 33
gmod_pin:
number: 1
gpio0_enable_pin:
number: 8
oe_pin:
number: 0
spv_pin:
number: 2
powerup_pin:
number: 4
wakeup_pin:
number: 3
vcom_pin:
number: 5
Inače radimo na tom da se ESPHome za Inkplate poboljša i bolje dokumentira na našoj novoj službenoj dokumentaciji, tako da hvala na ideji da možemo lakše pružiti ovo kroz config.
What voltage (approximately) would correspond to 0% battery charge? It’s great that you plan to work on ESPHome documentation.
puno hvala na informacijama i snippetu.
Sve radi
Još zadnje pitanje, koja voltaža (otprilike) bi odgovarala 0% napunjenosti baterije?
Super je ako imate u planu raditi dokumentaciju za ESPHome
Hvala još jednom!
Lp!
Inkplate will not discharge the battery down to literally 0%. Effectively 0% occurs when the display can no longer refresh and the ESP32 enters a boot loop where it constantly tries to draw enough current to start. From our testing, it is good to look at around 3.65 V. Your mileage may vary depending on the model and battery, but I suggest this as an initial value.
Inkplate bateriju neće spustiti doslovce do 0% već je efektivno 0% kad se display više ne može refreshati i ESP32 uđe u boot loop gdje stalno pokuša povući dovoljno struje kako bi se upalio. Iz naših pokusa to je dobro gledati oko 3.65 V. YMMV ovisno o modelu i o bateriji, to predlažem kao neki početnu vrijednost
