clearDisplay() does nothing. I’m calling display.begin(). None of the example code works.
I am able to print to Serial and the code is running. Using an Inkplate 10. I can write to the display with MicroPython.
Originally submitted via email support on 14 October 2023. Migrated to the forum for community visibility.
Try switching your board definition and test both ‘e-Radionica’ and ‘Soldered’ variations of the board definition for your board.
Also make sure you’re using the latest version of the board definitions and the library, as described in the getting started guide: Inkplate Get Started Page — Inkplate docs documentation
