Inkplate 10 disconnects from Linux with input/output error on flash
I’m connecting an Inkplate 10 to a Linux machine and it briefly appears at /dev/ttyUSB0, but then disappears. When I try to flash it using platformio, the connection sometimes succeeds if the device was just plugged in, but then fails with an input/output error. I’ve tried several USB A to USB C cables that work with other devices, and tried them in both directions. What could be causing this?
Originally submitted via email support on 29 April 2022. Migrated to the forum for community visibility.
I fixed this by adding an RTC battery and removing the brltty package. The device was disconnecting instantly after connecting, followed by a message about BRLTTY 6.4 Linux Screen Driver Keyboard appearing in the input devices.
Can you try connecting the Inkplate to another PC (Windows or Mac) and uploading code from there? Does your Inkplate work when connected to USB - does the display refresh?
This symptoms suggest a problem with the USB-UART communication IC or a power issue, which is why your Inkplate disappears from the device list.
