I just received my Inkplate 10 and I’m struggling to display Umlauts such as “öäüÖÄÜß”. They don’t seem to be contained in the fonts I’ve discovered so far. Can you recommend a method or font to display Umlauts on the device?
Originally submitted via email support on 22 July 2024. Migrated to the forum for community visibility.
These characters aren’t supported natively, as in Adafruit GFX which the Inkplate library is based on, only ASCII is supported.
For a project that needed to write in Arabic on Inkplate, I found the core of the Adafruit GFX library with full UTF-8 support, which has all the characters you need: https://blog.adafruit.com/2019/04/08/the-adafruit-gfx-library-now-supports-unicode-adafruit-adafruit-josecastillo/
I’ve made a version of the Inkplate library with UTF-8 support that I’ve tested on Inkplate 10: https://github.com/SolderedElectronics/Inkplate-Arduino-library/tree/utf8-support
It’s slightly unofficial but give that a try. There’s a step in the procedure where you select which character sets to include in the library (including all of UTF-8 would take a ridiculous amount of memory, so you can include only the required ones).
Be aware that only the default font is supported, which can look a bit blocky and not too pretty. If you get stuck or need me to go over exactly how I did this in my projects, let me know.
I tried the updated library you recommended but was unsatisfied with the default font. As a workaround I chose to display images instead of text.
The solution with displaying images is a good approach. You can render an image to display on Inkplate remotely and host that image at a constant address, periodically updating it on Inkplate.
