I have weather maps downloading to my SD card and displaying on my Inkplate 10. I’m trying to use two GPIO interrupts to scroll back and forwards through the maps. I initially chose GPIO12 and GPIO14. GPIO12 seems to work well but GPIO14 is very temperamental. It occasionally works after taking GPIO12 high but at other times won’t work at all. I’ve swapped the push buttons and pull down 10k resistors between the two ports to rule out external circuitry issues. I also tried GPIO pins 34 and 36 with external pull down resistors but without success. I am using esp_sleep_enable_ext1_wakeup. Do you have recommendations for which IO pins to use with two external push buttons? I’ve read that GPIO14 defaults to a high state - is there a function I should call to set it low?
Originally submitted via the contact form on soldered.com on 6 June 2025. Migrated to the forum for community visibility.
