Which Arduino is required to run the Inkplate 10, and can a Raspberry Pi be used instead?
Originally submitted via email support on 6 July 2022. Migrated to the forum for community visibility.
Inkplate 10 does not require any external microcontroller. An ESP32 microcontroller is built into Inkplate 10 for controlling the display. If you are familiar with Raspberry Pi, you can use Inkplate 10 in peripheral mode and control everything with the Raspberry Pi.
