Inkplate 10 missing touch pads from CrowdSupply
I received an Inkplate 10 with enclosure. I can’t see the touch pads that were supposed to be on the board. How do I get access to them, through the enclosure and directly on the board?
Originally submitted via email support on 17 June 2025. Migrated to the forum for community visibility.
Some Inkplates from CrowdSupply are the older version (e-Radionica Inkplate 10 board definition, some with touchpads), while others are the new version (Soldered Inkplate 10 board definition, all without touchpads). You’ll need to contact CrowdSupply directly if you want a version with touchpads.
Alternatively, if you prefer to keep your current board, you can use the available on-board GPIO to add your own touch pads, or add them over I2C/qwiic/easyC.
