I received an Inkplate 10 recently and the version I have does not have touch pads. Is there another way to wake and interact with the device in deep sleep mode apart from the wake button, such as wake-on-lan?
Originally submitted via email support on 6 December 2023. Migrated to the forum for community visibility.
The current version of Inkplate 10 does not have touchpads. You can wake up from the wake button or other GPIO pins using esp_sleep_enable_ext0_wakeup or esp_sleep_enable_ext1_wakeup. See the ESP32 datasheet for specifics of these two different functions (they correspond to different pins). Using this you can connect an external device like a gesture/touch/proximity sensor or any kind of sensor you prefer which generates an interrupt that you can connect to one of the pins.
