Inkplate 10 screen replacement after charger damage
After using the epub reader for a while, I connected the Inkplate 10 to a wall charger. The charger got hot and the screen became black and is not responding to any uploaded examples. I’m considering replacing the screen like you would with a smartphone. Is this possible, and do you have a recommended screen that would be compatible with the Inkplate 10 hardware?
Originally submitted via the contact form on soldered.com on 17 November 2023. Migrated to the forum for community visibility.
Yes, this is absolutely possible and much easier than replacing a smartphone screen. For Inkplate 10, these are the compatible ePapers:
ED097OC1
ED097OC4
ED097TC2
You can easily find them online. They need to be attached via the flat connector on the back of the device. When you attach it, I recommend calibrating the waveform using the Inkplate10->diagnostics->waveform_eeprom_programming, which will give you optimal picture quality on your new panel.
Do you have any recommendations for loosening the screen? A friend suggested using a hair blower. Are there other tips?
I consulted with colleagues in production about this. They recommend trying alcohol or acetone with a scalpel to get the old display off. They also mentioned there’s a good chance the old display might crack, but since it’s defective anyway, this shouldn’t be a concern.
