I have an issue with my Inkplate 10 that causes vertical lines and darker spots to appear over time, even when nothing is being drawn to it. Is this caused by incorrect drawing methods, or is it a problem with the panel itself?
Originally submitted via email support on 17 November 2021. Migrated to the forum for community visibility.
Which version of the library are you using?
This problem was fixed in library version V5.5.0. Please update to that version and check the image.
If you have a darker image, try the solution described in the topic at https://forum.e-radionica.com/en/viewtopic.php?f=23&t=407#p810
The latest version of the Inkplate library available in Arduino is V5.0.0. We have made additional releases, but these are not yet updated in the Arduino library manager. You can download the Inkplate library directly from our GitHub repository and install it manually in Arduino, or wait a few days until it becomes available through the Arduino library manager.
