I followed the setup instructions and everything worked fine, but when I tried to upload one of the examples from the basic folder, it doesn’t work. The sketch compiles for about 10 minutes and then gives this error:
Sketch uses 310169 bytes (9%) of program storage space. Maximum is 3145728 bytes.
Global variables use 32016 bytes (9%) of dynamic memory, leaving 295664 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.2.1
Serial port COM3
Connecting……………………………….
A fatal error occurred: Failed to connect to ESP32: No serial data received.
For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
I’ve verified that the correct USB port and board are selected. I’ve tried:
- Setting upload speed to 115200 (was previously 921600)
- Different USB-C cables
- Different computers
- Different USB ports
- Old Arduino IDE and new IDE (both up to date)
- All possible combinations of these
Originally submitted via email support on 26 October 2023. Migrated to the forum for community visibility.
