Inkplate 10 upload fails with serial corruption error on macOS
I received my Inkplate 10 and when I powered it up all was working fine—I could cycle through the screen with the wake up button. Then when I tried to upload one of the basic examples (Hello World) from my Arduino IDE after selecting the correct board and port, I got this error:
Sketch uses 340173 bytes (10%) of program storage space. Maximum is 3145728 bytes.
Global variables use 37080 bytes (11%) of dynamic memory, leaving 290600 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.5.1
Serial port /dev/cu.usbserial-10
Connecting….
Chip is ESP32-D0WD-V3 (revision v3.1)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: e8:6b:ea:f9:eb:88
Uploading stub…
Running stub…
Stub running…
Changing baud rate to 921600
Changed.
A fatal error occurred: Unable to verify flash chip connection (Serial data stream stopped: Possible serial noise or corruption.).
The screen is now stuck and pressing next does not work anymore. I already tried powering off and on, and holding the reset button while powering on. What should I do?
Originally submitted via email support on 18 January 2026. Migrated to the forum for community visibility.
The issue is likely caused by the onboard CH340 driver on the Inkplate device having problems at higher baud rates on macOS. In your Arduino IDE, go to Tools → Upload Speed and change it to 460800 baud. This should resolve the error.
