Inkplate 2 and 5 battery life and power consumption for updates
I couldn’t find information on your website about battery runtime for your Inkplate displays. I’m interested in how much current the display updates consume.
I’m considering buying either an Inkplate 2 or 5, but I’d like to update the display frequently throughout the day and run it on battery. Is there any specification for how many updates the displays can perform before the battery needs to be recharged?
Original message (German)
Ich habe auf eurer Website Leider nichts zur akkulaufzeit von euren inkplate Displays gefunden. Mich würde interessieren wie viel Strom das aktualisieren die Displays verbraucht.
Ich bin derzeit am überlegen mir ein inkplate 2 oder 5 zu kaufen allerdings würde ich gerne das Display gerne häufiger am Tag aktualisieren und mit Akku betrieben. Gibt es eine Angabe wie viele Aktualisierungen die Displays schaffen bis der Akku wieder geladen werden muss?
Originally submitted via email support on 29 October 2023. Migrated to the forum for community visibility.
The detailed power consumption we’ve documented for our Inkplate devices can be found on their respective Crowdsupply pages. The exact number of updates until the battery is depleted naturally depends on the capacity of the battery you use. We have versions of Inkplate that come with a battery, but in your own setup you can use a battery of any capacity. The number of updates also depends on how often the Inkplate wakes up and what your code does exactly. Therefore, we cannot provide an exact number.
Inkplate 5 has a built-in circuit that can read the battery voltage, which can give you an indication of the charge level—so you can have a low battery warning, which might be useful. Inkplate 2 unfortunately does not have this, purely due to space constraints. I hope this information is helpful for you.
der genaue Stromverbrauch, den wir für unsere Inkplate-Geräte dokumentiert haben, ist am besten auf ihren jeweiligen Crowdsupply-Seiten zu finden. Die genaue Anzahl der Aktualisierungen bis der Akku leer ist, hängt natürlich von der Kapazität des von Ihnen verwendeten Akkus ab. Wir haben Versionen von Inkplate, die mit einem Akku geliefert werden, aber Sie können in Ihrem eigenen Aufbau einen Akku beliebiger Kapazität verwenden. Die Anzahl der Aktualisierungen hängt auch davon ab, wie oft das Inkplate aufwacht und was Ihr Code genau macht. Daher können wir keine genaue Zahl angeben.
Inkplate 5 hat eine eingebaute Schaltung, die die Akkuspannung lesen kann, was Ihnen einen Hinweis auf den Ladezustand geben kann - so können Sie eine Warnung bei niedrigem Akkustand haben, was nützlich sein könnte. Inkplate 2 hat dies leider nicht, und das nur aufgrund von Platzbeschränkungen. Ich hoffe, diese Informationen sind für Sie nützlich.
