Inkplate 2 display.display() executes instantly without refreshing screen
I added Serial.println statements before and after display.display() and it worked fine for over 5 days, but today it stopped refreshing the display entirely. Both Serial.println lines print to the monitor, but display.display() doesn’t do anything and executes in under a second. Normally display.display() takes multiple seconds to draw to the screen (see screenshot). I’m using only a barebone Inkplate 2 from Kickstarter connected via USB-C to a PC, with no battery or external devices. What else could fix this?
Attachment omitted in migration: Screenshot 2024-01-19 130044.png
Originally submitted via the contact form on soldered.com on 19 January 2024. Migrated to the forum for community visibility.
You were right to notice that display.display() doesn’t take any time to execute. Let’s investigate further. Open the Inkplate library on your computer and find Inkplate2.cpp.
I’ve made a modified Inkplate2.cpp with debug messages that will print the state of the display.display() function to Serial so we can see what’s happening. You can find it here: https://pastebin.com/raw/jVBdy4z8
Replace all the code in your Inkplate2.cpp with the code from this pastebin and run the example again. I think waitForEpd is getting completely skipped.
