Inkplate 2 MicroPython setup: could not enter raw repl error
I’m following the setup instructions from the MicroPython repository. After flashing the ESP32 with esptool, when I run the pyboard.py command to copy the files, I get a “could not enter raw repl” error:
C:\Users\[user]\Inkplate-micropython-master>python pyboard.py --device COM11 -f cp inkplate2.py gfx.py gfx_standard_font_01.py mcp23017.py PCAL6416A.py image.py shapes.py soldered_logo.py
b'ets Jul 29 2019 12:21:46\r\n\r\nrst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)\r\nconfigsip: 0, SPIWP:0xee\r\nclk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00\r\nmode:DIO, clock div:2\r\nload:0x3fff0030,len:4540\r\nho 0 tail 12 room 4\r\nload: ,len:12788\r\nload: ,len:4176\r\nentry \r\nMicroPython v1.18 on 2022-01-17; ESP32 module (spiram) with ESP32\r\nType "help()" for more information.\r\n>>> '\ncould not enter raw repl
Originally submitted via email support on 23 June 2024. Migrated to the forum for community visibility.
When you get the ‘could not enter raw repl’ error, try running the command again. The readme notes that this command may have to be started twice.
I re-ran the command as instructed, but now I’m getting a different error. After running pyboard.py twice, the second attempt shows:
cp :inkplate2.py soldered_logo.py
 File "", line 1, in
OSError: [Errno 2] ENOENT
The command I ran was:
I tested this myself. Make sure you’re running the pyboard.py command in the MicroPython folder. The working command includes a semicolon at the end:
python pyboard.py --device COM10 -f cp inkplate2.py gfx.py gfx_standard_font_01.py image.py shapes.py soldered_logo.py :
Note the : at the end of the command.
