I received 2 Inkplate 2 boards and tried some examples on one, including the world clock example. After this, the screen has stopped updating completely. I can download new code to the board and the serial monitor responds as expected, but the screen never updates—even simple text display examples don’t work. The other Inkplate 2 I received works as expected with the same example, same laptop, and same USB cable. The ribbon cable appears to be correctly seated on the board. How can I fix the display?
Originally submitted via email support on 29 May 2023. Migrated to the forum for community visibility.
Update your Inkplate library to the latest version and load the Black-White-Red example. The library was recently updated with improvements to how the Inkplate 2 display re-initializes, which may resolve your issue. Get the latest version here: GitHub - SolderedElectronics/Inkplate-Arduino-library: Inkplate family Arduino library. The easiest way to add e-paper to your project. · GitHub
If that doesn’t work, try re-connecting the flat cable that connects the ePaper display to the main board. This has sometimes resolved this issue.
Procedure:
- Disconnect Inkplate 2 completely from power or USB.
- Dethatch the flat cable holder by gently pulling on the catch/release mechanism in the noted direction.
- Take the flat cable out, keeping in mind to bend it as little as possible.
- Connect it back together and secure with the mechanism. Make sure the connection is solid.
- Upload the Inkplate2_Black_White_Red example, which should always refresh the display.
