I’m trying to load the first simple example onto my Inkplate 2 but get a StopIteration error during upload.
Serial port: /dev/ttyUSB0
Chip: ESP32-D0WD-V3 (revision 3)
Crystal: 40MHz
The upload process progresses through several stages:
- Connecting
- Chip detected with WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
- MAC: c4:de:e2:26:3e:5c
- Stub uploaded and running
- Baud rate changed to 921600
- Then fails at “Configuring flash size”
Full error trace:
File "/home/[user]/.arduino15/packages/Inkplate_Boards/tools/esptool_py/4.2.1/esptool.py", line 34, in <module>
esptool._main()
File "/home/[user]/.arduino15/packages/Inkplate_Boards/tools/esptool_py/4.2.1/esptool/__init__.py", line 1004, in _main
main()
File "/home/[user]/.arduino15/packages/Inkplate_Boards/tools/esptool_py/4.2.1/esptool/__init__.py", line 790, in main
esp.flash_set_parameters(flash_size_bytes(args.flash_size))
File "/home/[user]/.arduino15/packages/Inkplate_Boards/tools/esptool_py/4.2.1/esptool/loader.py", line 1108, in flash_set_parameters
self.check_command(
File "/home/[user]/.arduino15/packages/Inkplate_Boards/tools/esptool_py/4.2.1/esptool/loader.py", line 406, in check_command
val, data = self.command(op, data, chk, timeout=timeout)
File "/home/[user]/.arduino15/packages/Inkplate_Boards/tools/esptool_py/4.2.1/esptool/loader.py", line 375, in command
p = self.read()
File "/home/[user]/.arduino15/packages/Inkplate_Boards/tools/esptool_py/4.2.1/esptool/loader.py", line 307, in read
return next(self._slip_reader)
StopIteration
I attempted to modify MEM_END_ROM_TIMEOUT in loader.py but that didn’t resolve it.
Originally submitted via email support on 14 May 2023. Migrated to the forum for community visibility.
