Inkplate 4 MicroPython setup fails with AttributeError: type object 'Inkplate' has no attribute 'GFX'
I cannot get Inkplate 4 to work with MicroPython. I also cannot find board definitions for Inkplate 4 in the Arduino board definitions, and ESP-IDF does not mention Inkplate 4 either. Is this working software for Inkplate 4?
I followed the guide at GitHub - SolderedElectronics/Inkplate-micropython: MicroPython driver for Soldered Inkplate devices · GitHub but some steps did not work.
When running:
python3 esptool.py –chip esp32 write_flash -z 0x1000 -v1.18.bin
I get:
Warning: Deprecated: Command 'write_flash' is deprecated. Use 'write-flash' instead.
esptool.py v4.8.1
Connected to ESP32 on /dev/ttyUSB0:
Chip type: ESP32-D0WD-V3 (revision v3.1)
Features: Wi-Fi, BT, Dual Core + LP Core, 240MHz, Vref calibration in eFuse, Coding Scheme None
Crystal frequency: 40MHz
MAC: e8:6b:ea:fb:de:08
Stub flasher running.
Configuring flash size…
Flash will be erased from to 0x0018ffff…
Compressed 1631216 bytes to 1052559…
I cannot get past this last step:
Inkplate-micropython# python3 pyboard.py –device /dev/ttyUSB0 "Examples/Inkplate4/basicBWR.py"
File "", line 16, in
File "inkplate4.py", line 72, in begin
File "inkplate4.py", line 269, in setRotation
Originally submitted via email support on 14 May 2025. Migrated to the forum for community visibility.
The MicroPython module for Inkplate 4 was written for a different model. For Inkplate 4, you should use our Arduino library instead:
The Arduino library is much more feature-packed. The MicroPython repository offers a basic implementation that was a code contribution which we attempted to fit to different Inkplate models.
