I have an Inkplate 5 Gen2 without a battery and would like to add one. Which battery size is suitable?
Originally submitted via email support on 27 June 2025. Migrated to the forum for community visibility.
If you have the case, it has a slot for a 1200 mah battery with dimensions 59.5 x 36.5 x 5 mm / 2.3 x 1.4 x 0.2 inch.
If you’re making your own case, you can fit as large of a battery as you can find.
