I was in contact with the distributor who will refund the defective boards. Do you have functional boards on stock with working TPS65186 PMIC?
Originally submitted via the contact form on soldered.com on 20 February 2026. Migrated to the forum for community visibility.
Yes, the TPS65186 chip failure can happen sometimes but it’s clearly not expected. All working Inkplate boards have this functioning chip. Let me know which Inkplate models you’re interested in, and I can have them be additionally tested before they’re shipped out.
I’ve placed an order for 4 units. How can you guarantee that the display will work long-term?
Each unit is tested when it leaves our manufacturing to ensure it works. E-paper displays have a relatively long lifespan depending on how often you refresh them. Constant non-stop partial updates might wear the display out, but using it in standard e-paper usage - for example updating every 10 minutes and mixing partial and full updates to preserve the screen - will keep your e-paper running for years.
