Inkplate 5V2 automatic startup when powered on
I noticed that it’s necessary to press the POWER button on the Inkplate 5V2 for it to start. How can I make it so that it starts automatically by default as soon as it’s plugged in?
Originally submitted via email support on 22 July 2025. Migrated to the forum for community visibility.
You can make the device start automatically by soldering a 0-ohm resistor (or jumper wire) to the pads highlighted in the attached image.
Important: Once this jumper is in place, the device can no longer be turned off using the power button. To restore normal functionality, you’ll need to desolder the jumper.
Attachment omitted in migration: image (8).png
