Inkplate 5v2 power-on bypass and V5 breakout pins
I recently acquired an Inkplate 5 for a LoRa network project. I have two questions:
  1. What do I need to solder or connect to make the Inkplate power on immediately when it receives power, bypassing the tactile button?
  2. Is there a version that includes the V5 (USB power rail) in the breakout pins?
Prije svega: hvala sto postojite. Istovremeno sam posramljen i zavidan cinjenicom da tek sada saznajem kako ste hrvatska firma.
Svaka vam cast.
Uzeo sam Inkplate 5 (Preko Mousera. Znam.) u prospektu koristenja za jedan projektic na nasoj lora mrezi. Ugodno sam iznenadjen kvalitetom i detaljima do kojih ste doveli taj projekt i ekosistem.
Da ne davim, samo dva pitanja:
  1. Sto moram sprziti/iscupati/zalemiti da bi se Inkplate palio cim dobije napajanje? (bypass taktilnog gumbica)
  2. Postoji li verzija koja ima i V5 (usb power rail) u breakout pinovima?
Puno Vam hvala unaprijed,
Originally submitted via email support on 11 January 2025. Migrated to the forum for community visibility.
To make the Inkplate power on immediately, there is a jumper on the board that can be connected. On the board, VIN (5V on our boards) is located at the top of the board.
hvala na lijepim riječima :slight_smile: stvarno na puno znači, podijeliti ću ih s timom.
Evo odogvora,
da bi se Inkplate palio odmah, postoji ovaj jumper koji se može spojiti:
Na pločici se nalazi ovdje:
Gore na pločici postoji VIN koji je 5V na našim pločicama:
Nadam se da informacije pomažu :slight_smile:
I should have mentioned this is the v2. The layout is different. I have a photo attached. I’m aware I may have damaged the 3V3 pin.
[name removed], hvala puno na brzome odgovoru!
Izostavio sam napomenuti: V2! Raspored je drugaciji. Slika u prlogu, znam da je garancija otisla sa mojim zlostavljanjem 3V3 pin-a :slight_smile:
  • Founder & CEO
    Notum Robotics d.o.o.
    [phone removed] / https://n-r.hr
Attachment omitted in migration: IMG_6131.jpg
For the 5v2, the jumper location is here: [photo reference]. From your photo, it looks like you have something interesting connected - is that the LoRa module?
Nema na čemu na pomoći,
aha jasno, 5v2, evo gdje se nalazi:
Koliko vidim sa slike, to je ovo:
Vidim da je nešto zanimljivo spojeno, to je taj LORA modul ? :slight_smile:
