I have a bricked paperwhite and would like to make use of the display as it’s still perfect. Are you selling just the board and/or casing for the Inkplate 6?
Originally submitted via email support on 10 September 2023. Migrated to the forum for community visibility.
The Inkplate 6 board is available with enclosure. The part number of the screen to use with this board is ED060SC7, which should work as expected. If you have a different screen, compatibility can be checked with one of the other boards.
A sketch is available to calibrate the VCOM according to your particular display so it will work optimally.
The casing is an open-source file which you can 3D print yourself. A 1200 mAh battery is also available separately.
For a specific inquiry to get just the casing and battery along with the board, contact support to arrange this.
