Inkplate 6 bypass power latch to auto-enable on power
I have an Inkplate 6 with enclosure. Is there any recommended way to bypass the power latch functionality, so the inkplate automatically turns on when power is connected? I found this part in the schematics. Should I just populate the R18 with a zero ohm resistor?
Attachment omitted in migration: 22C882EA87CA4D5BB0839F3D61221424.png
Attachment omitted in migration: 0D4C27978C514D679328EDDCA9BCAD6C.png
Originally submitted via email support on 12 March 2024. Migrated to the forum for community visibility.
You’re correct, you can do it even with just solder and solder it together like a bridge, but a zero ohm resistor is a more elegant solution.
