I have an Inkplate 6 and want to power it with the LI-ION BATTERY 4000MAH 3.7V (SKU: 101390). Can you confirm that the BATTERIES WITH 5V OUTPUT charger (SKU: 222220) is compatible? If not, which charger should I use?
Originally submitted via email support on 4 August 2021. Migrated to the forum for community visibility.
The charger SKU 222220 is compatible with the LI-ION BATTERY 4000MAH 3.7V.
The 4000 mAh battery is slightly larger than the standard battery for Inkplate 6. If you plan to use it without the case, it should work fine. The recommended battery for Inkplate is the LI-ION BATTERY 1200MAH. Let me know if you would like to proceed or if you have other questions.
