After installing recommended library updates including SdFat, example sketches no longer compile. I’m getting this error:
/Users/[user]/Documents/Arduino/libraries/Inkplate_6_Arduino_library_master/Inkplate.cpp:7:15: error: no matching function for call to 'SdFat::SdFat(SPIClass*)'
SdFat sd(&spi2);
In file included from /Users/[user]/Documents/Arduino/libraries/Inkplate_6_Arduino_library_master/Inkplate.h:17:0,
from /Users/[user]/Documents/Arduino/libraries/Inkplate_6_Arduino_library_master/Inkplate.cpp:4:
/Users/[user]/Documents/Arduino/libraries/SdFat/src/SdFat.h:310:7: note: candidate: SdFat::SdFat()
class SdFat : public SdFileSystem {
/Users/[user]/Documents/Arduino/libraries/SdFat/src/SdFat.h:310:7: note: candidate expects 0 arguments, 1 provided
/Users/[user]/Documents/Arduino/libraries/SdFat/src/SdFat.h:310:7: note: candidate: constexpr SdFat::SdFat(const SdFat&)
/Users/[user]/Documents/Arduino/libraries/SdFat/src/SdFat.h:310:7: note: no known conversion for argument 1 from 'SPIClass*' to 'const SdFat&'
/Users/[user]/Documents/Arduino/libraries/SdFat/src/SdFat.h:310:7: note: candidate: constexpr SdFat::SdFat(SdFat&&)
/Users/[user]/Documents/Arduino/libraries/SdFat/src/SdFat.h:310:7: note: no known conversion for argument 1 from 'SPIClass*' to 'SdFat&&'
Multiple libraries were found for "SdFat.h"
Used: /Users/[user]/Documents/Arduino/libraries/SdFat
Not used: /Users/[user]/Documents/Arduino/libraries/Inkplate_6_SDFat_Arduino_Library_master
exit status 1
Error compiling for board Inkplate 6(ESP32).
The error repeats when I try to compile. What should I do?
Originally submitted via email support on 29 July 2020. Migrated to the forum for community visibility.
I tried reverting to the old SdFat library but it still doesn’t work. The problem might be that Arduino suggested upgrading another file along with SdFat, and since I don’t remember the name of that second file, I can’t undo that upgrade either. What’s the easiest way to fix this?
I’ve managed to get Inkplate to display one bitmap, or another bitmap using your sample code. However, when I tried to modify the code to display bitmap1, pause, then show bitmap2, it didn’t work. Do you have sample code to display 3 or 5 pictures with editable delays between them?
Also, do you have sample code for a weather station?
One more question: how do I get the serial port installed on macOS Catalina? The serial port that was listed in Arduino’s port selection seems to have disappeared.
Great that you’ve resolved the IDE issue and are working with the library.
The issue with displaying multiple images is likely a logic error in your code. Are you loading the images from the SD card?
We have a weather station example in development. Check it here: https://github.com/e-radionicacom/Inkplate-6-Arduino-library/tree/master/examples/3.%20Projects/1-Weather_station_example
For the serial port issue on macOS: if you had the port working once, the drivers are already installed. Try restarting your Mac or using a different port. Similar issues with macOS are common.
How do I download and use the weather station code? Which files should I copy where to get the weather station working? I don’t see a clear download button. I’m not very familiar with GitHub, and I’ve read the instructions multiple times but still find it confusing.
I’ve written an example that loads image1.bmp, image2.bmp and image3.bmp from your SD card and displays them with a 45 minute delay between each. Put the BMP files on your SD card with those exact filenames and try the code.
To display 5 images, it’s just a small code change—try looking at the example and modifying it.
To use the other examples like the weather station:
- Download the library from GitHub - SolderedElectronics/Inkplate-Arduino-library: Inkplate family Arduino library. The easiest way to add e-paper to your project. · GitHub
- Follow the installation tutorial at https://www.baldengineer.com/installing-arduino-library-from-github.html
- Once installed, go to File → Examples → Inkplate → Projects → Weather station
- Add your WiFi network name and password to the example so Inkplate can connect
Attachment omitted in migration: Marus-show-3-bmps.ino
