I’m using an Inkplate 6 connected to a Raspberry Pi 5 over serial via USB-C. An Arduino sketch consumes JSON from a Python app running on the Pi and renders to Inkplate after parsing the JSON. Each JSON emission is an enumeration of lines the app needs to display with an update field that tells the Inkplate which lines to partialUpdate.
I’m experiencing unexpected behavior: when the user types quickly (around 3-4 keypresses per second), the Inkplate performs a full flashing refresh instead of partial updates. I’m using a third-party library by Larry Bank rather than Soldered’s drivers, as I found it significantly faster.
Is the full refresh an internal response to throttling built into Inkplate’s microcontroller, or is there a reason for this behavior that I can’t overwrite?
Originally submitted via the contact form on soldered.com on 22 May 2025. Migrated to the forum for community visibility.
