Inkplate 6 e-ink display not updating (still has the default from the factory image)
I have recently purchased an Inkplate 6. On the bottom right hand corner of the back of the PCB is a mark of “v1.2.0”.
I started by trying to install Homeplate and when that did not work as the ESP32 could not connect to my home’s WiFi, I tried the Quick start guide.
This did not work either so I then tried to run the Inkplate6_Burn_In_Clean.ino from the examples provided in Arduino IDE. Running this results in the control sections of the panel blinking but the display is not cleared.
I have looked on the forum for similar issues and tried disconnecting and reconnecting the cable to the display on the back. This has not solved the issue.
There is no obvious damage to the PCB or the display panel. The power LED turns on as expected. My phone could connect to the board when it was acting as a WiFi access point when I was trying to configure Homeplate.
I would appreciate if you are able to help me fix this or clarify if the issue is defective hardware.
Can you try running the black and white example? You can find it in Arduino under Basic examples.
Thank you for getting back to me.
I have now uploaded Inkplate6_Black_And_White.ino to my Inkplate 6 and the same behaviour persisted. The area circled in red flashed every time the board tried to refresh the display, but the image on the display did not change. I hope this clarifies the problem that I am having.
My apologies for the glare in the photo from the lights in the celling.
Sorry about that, it seems to be a defect. For a replacement/return, contact us via hello@soldered.com email with your order number and either a link to this forum thread or explaining the issue.
