I got my hands on Inkplate 6 and tried to get started with one of your examples. But it keeps crashing/dumping. After adding some logs, it appears the dump occurs as soon as it actively accesses the display, like display.display() or display.print(“Welcome to Inkplate 6!”);
Core 1 register dump:
PC : 0x4008a7bc PS : 0x00060d30 A0 : 0x800d7f61 A1 : 0x3ffb2120
A2 : A3 : A4 : 0x0000ea60 A5 :
A6 : 0x00ff0000 A7 : 0x00000ea6 A8 : A9 : 0x3ffb2100
A10 : 0x3ffbdb80 A11 : 0x3f4104a2 A12 : A13 : 0xffffffff
A14 : 0x00ff0000 A15 : 0xff000000 SAR : EXCCAUSE: 0x0000001c
EXCVADDR: LBEG : 0x4008a7bc LEND : 0x4008a7d2 LCOUNT : 0x00000ea5
Backtrace: 0x4008a7b9:0x3ffb2120 0x400d7f5e:0x3ffb2130 0x400d73cf:0x3ffb2160 0x400d2e5a:0x3ffb2180 0x400db869:0x3ffb2290
Originally submitted via email support on 14 February 2025. Migrated to the forum for community visibility.
Try running Inkplate6_Black_And_White.ino unmodified. Check that you’re using the correct board definition in the Tools menu in Arduino. We recommend Arduino 2.0 and newer.
The partition scheme may be different from default. For board definitions, refer to: Inkplate Arduino — Inkplate docs documentation
Try the following steps:
- Try a different USB cable and/or USB port
- Try a totally empty sketch with nothing
- Do you have the latest version of the library and board definitions? Sometimes doing a hard reinstall of this can fix these issues.
Regarding line strength/darkness, this is due to the waveform. The micropython library affects the e-Paper differently or has a different VCOM value. VCOM is a negative voltage used to calibrate the darkness of the e-Paper panel.
You can try calibrating the VCOM in Arduino mode yourself. Try values between -1.5 to -2.5 and see what looks best. Here’s a modified Factory_programming_VCOM example for Inkplate 6 that sets the VCOM: https://pastebin.com/raw/0CYjiKkB
Inkplate 6’s resolution is 800x600. Could you draw a simple fillRect at 0, 0, 800 wide 600 tall in BLACK and take a picture of the display?
Check the sticker on the flat cable - some e-Paper panels have the VCOM written there (something like -1.56 or -2.43). If not, try the range -1.5 to -2.5 and see what looks best for you.
