Inkplate 6 Flick touch screen not responding to input
My Inkplate 6 Flick’s touch screen is not working. I tried using the example projects and none of them work.
Originally submitted via email support on 24 August 2025. Migrated to the forum for community visibility.
Sometimes this is caused by noise on the flat cable connector. Try placing aluminum foil on the connector to provide shielding. We have seen some of these connectors have serious problems with noise/shielding. When you place the aluminum foil, it will stabilise the connector. Then try the example again with the foil on.
