I’m using Inkplate 6 (older version, the e-radionica Inkplate) for my final project and need to send certain information over the I2C port.
Inkplate receives messages normally until I include the inkplate.h library and initialize the display. After adding that, communication doesn’t work, neither with the onReceive function nor by checking Wire.available within the loop function in the Arduino program.
Currently I’m sending data over the I2C pins on the board side. Does it make a difference if I use the easyC port?
Does the display mode matter?
Is this a known issue and does someone have a temporary solution I can use?
koristim Inkplate 6 (starija verzija, tj. e-radionica Inkplate) za završni rad i trebam poslati određene informacije preko i2c porta.
Inkplate normalno prima poruke sve dok ne uključim inkplate.h library i inicijaliziram display. Pri dodavanju toga, komunikacija ne radi, niti sa onReceive funkcijom, niti provjeravanjem Wire.available unutar loop funkcije u arduino programu.
Trenutno šaljem podatke preko i2c pinova na strani ploče, ima li razlika ako koristim easyC port?
Da li ima veze u kojem je modu display?
Da li je problem poznat i ima li neko privremeno rješenje koje mogu koristiti?
Lp, [name removed]
Originally submitted via email support on 18 February 2024. Migrated to the forum for community visibility.
