Inkplate 6: loading pictures and DHT11 library setup
I have installed drivers, software and library (GitHub - SolderedElectronics/Inkplate-Arduino-library: Inkplate family Arduino library. The easiest way to add e-paper to your project. · GitHub). How do I load pictures into the device?
Also, why can’t I find DHT11 in the libraries? What should I do next?
Originally submitted via email support on 9 September 2020. Migrated to the forum for community visibility.
Set up your Arduino IDE using the manual at Inkplate Documentation | Soldered Documentation
After you go through the process, you will be able to access the examples using File → Examples → Inkplate. That should be your starting point.
