How long would the Inkplate 6 MOTION last on a single charge if used as a magazine/ebook reader with the rotary button for scrolling through pages?
Originally submitted via email support on 27 June 2024. Migrated to the forum for community visibility.
The CR2032 battery is for powering the RTC if the device goes in deep sleep, so that it retains the time written to it.
You can use this as a magazine/ebook reader by developing the code for it. The product is a development board with e-Paper, so what you want to make is entirely up to you. This use case is definitely doable - there are examples of people using Inkplate for this purpose: GitHub - turgu1/EPub-InkPlate: An EPub Reader for the ESP32 based InkPlate e-Ink devices. · GitHub
The board supports connecting a li-ion battery through a JST connector. There is a version of the product that comes with this battery (Inkplate 6 MOTION With Enclosure & Battery). It will automatically charge the battery when connected to USB.
On a single charge, the battery can last quite a while if deep sleep is implemented (we have code examples for this). For example, users with weather station type projects have observed a month on a single charge, because the device only wakes up once per hour to update the display. If you were to use it in an e-Reader way, you could get a day’s use out of it, depending on how often you’re polling the rotary encoder. It’s hard to approximate precisely.
