I’m experiencing a Linux-specific issue uploading sketches to Inkplate 6 MOTION. On Windows it works fine, and I can upload to Arduino Micro boards on Linux without problems, but Inkplate 6 MOTION behaves differently.
On Linux, when I press the programming button, the serial output shows “Programming mode active.” However, after a Linux upload, the program doesn’t execute and pressing the programming button produces no serial output.
Attempting to upload sketches with BOOT position 0 fails with: “Timeout error occured while waiting for acknowledgement. Error: Activating device: KO. Please, verify the boot mode configuration and check the serial port configuration.”
Switching to BOOT position 1 with reset allows successful upload but produces no result on screen, no behavior change, and no serial output when pressing the programming button.
I’m running Arduino IDE 2.3.6 with Inkplate Library 1.0.1, Inkplate MOTION Boards 1.0.2, and STM32Programmer 2.20.0. The sketch compiles successfully (158744 bytes, 7% of storage).
Full error output:
sh "/home/username/.arduino15/packages/Inkplate_Motion/tools/STM32Tools/2.2.1-0/stm32CubeProg.sh" 1 "/home/username/.cache/arduino/sketches/A1BF44/Inkplate_6_Motion_Simple_BW.ino.bin" 0x0 ttyUSB0
STM32CubeProgrammer v2.20.0
Serial Port ttyUSB0 is successfully opened. Port configuration: parity = even, baudrate = 230400, data-bit = 8, stop-bit = 1.0, flow-control = off
Reset your device then try again...
I’m open to alternative methods using arduino-cli or STM tools directly, or beta testing ESPhome if available.
Originally submitted via the contact form on soldered.com on 22 September 2025. Migrated to the forum for community visibility.
