I’ve successfully installed the STM32 Programmer and Dasduino with Arduino on Linux, and Arduino can see the Inkplate 6 MOTION. However, when I try to program after hitting the program button, I get a timeout error while waiting for acknowledgement. Is there a time limit between pressing the program button and upload start? Does it need to be held down? Are there specific upload method settings or serial defaults I should be using?
The upload attempt seems to have done something, as the default intro program is no longer running.
When the switch is set to BOOT 0:
Serial Port ttyUSB0 is successfully opened.
Port configuration: parity = even, baudrate = 230400, data-bit = 8, stop-bit = 1.0, flow-control = off
Timeout error occured while waiting for acknowledgement.
Error: Activating device: KO. Please, verify the boot mode configuration and check the serial port configuration. Reset your device then try again…
When the switch is set to BOOT 1:
RUNNING Program …
Address: : 0x8000000
Error: START command not acknowledged!
Error: Start operation failed
When I use Get Board Info it returns:
BN: Unknown board
VID: 0x1a86
PID: 0x7523
SN: (null)
Originally submitted via email support on 2 February 2025. Migrated to the forum for community visibility.
