I ordered the Inkplate 6 and was very happy with it, but when I experimented with it yesterday, the panel suddenly wouldn’t update anymore. The serial communication with ESP32 still works and so I tried to upload a program that just tried to clear the screen, but that didn’t work either. Today I measured some voltages on the circuit board and found out that the ESP32 still got the proper 3.3V on its input and the TPS65186 also got 4.7V on the input pin. The outputs of the TPS driver chip on the other hand only had small voltage levels above zero volts instead of the required +15V and -15V. So I think either the driver chip itself or one of its support components has failed.
Original message (German)
a while ago I ordered the Inkplate 6 and was very happy with it, but
when I experimented with it yesterday, the panel suddenly wouldn´t
didn´t work either. Today I measured some voltages on the cirucuit board
and found out, that the ESP32 still got the proper 3,3V on its input and
the TPS65186 also got 4,7V on the input pin. The outputs of the TPS
components has failed, but I´m not able to replace such small
components. Is it possible for you to replace just the board assembly
without the panel or at least let me order the board assembly without
the panel?
Originally submitted via email support on 24 November 2020. Migrated to the forum for community visibility.
