Inkplate 6 screen not displaying after code upload
I received the board and can upload code via Arduino IDE, but the screen is not displaying anything. I believe the unit may be defective. I removed the blue cover from the ribbon cable and verified it was connected. The pins look fine to me.
Originally submitted via email support on 23 December 2025. Migrated to the forum for community visibility.
What board definition are you using? The Inkplate 6 has an older version called the e-radionica Inkplate 6 (with a blue PCB) and the Soldered Inkplate 6 with a purple one. The board selected in the Arduino IDE should match the one you have. This is documented in the following link: Inkplate 6 - Quick start guide | Soldered Documentation.
If the panel doesn’t refresh with the correct board definition and running a basic example, then we can start with the replacement process.
