Inkplate 6 SD card file read fails with file.open()
I have an Inkplate 6 and want to write something to a text file on an SD card and then read that same file. I combined your write and read examples into a single sketch.
Writing to the text file works, but reading from it does not.
Specifically this line fails:
file.open("/text.txt", O_RDONLY)
Here is the code:
#if !defined(ARDUINO_ESP32_DEV) && !defined(ARDUINO_INKPLATE6V2)
#error "Wrong board selection for this example, please select e-radionica Inkplate6 or Soldered Inkplate6 in the boards menu."
#endif
#include "SdFat.h" //Include library for SD card
SdFile file; // Create SdFile object used for accessing files on SD card
char *fileName = "test.txt"; // The name of a file with the extension.
boolean fileRead = false;
int numOfAttempts = 0;
// The text you want to write in the file
char *dataToWrite = "Hello! This is the file writing example for Inkplate 6.\n"; // "\n" represents a new line
void setup()
  display.setTextSize(3);
  // Init SD card. Display if SD card is init propery or not.
  if (display.sdCardInit())
    display.println("SD Card ok! Reading data…");
    display.partialUpdate();
    // Try to create text.txt file.
    if (!file.open(fileName, FILE_WRITE))
    { // If it fails to create, send an error message to display, otherwise write to file.
      display.println("Error while creating the file!");
      display.sdCardSleep();
void loop() {
  if (!fileRead) {
    if (!display.sdCardInit()) {
      display.println("Unable to initialize SD Card!");
    if (!file.open("/text.txt", O_RDONLY))
    { // If it fails to open, send error message to display and put sd card in sleep mode, otherwise read the file.
      display.println("File open error");
      display.display();
      numOfAttempts++;
      if (numOfAttempts >= 5) {
        fileRead = true;
    else
      fileRead = true;
      display.clearDisplay(); // Clear everything that is stored in frame buffer of epaper
      display.setCursor(0, 0); // Set print position at the begining of the screen
      char text[200]; // Array where data from SD card is stored (max 200 chars here)
      int len = file.fileSize(); // Read how big is file that we are opening
      if (len > 200)
        len = 200; // If it's more than 200 bytes (200 chars), limit to max 200 bytes
      file.read(text, len); // Read data from file and save it in text array
      text[len] = 0; // Put null terminating char at the and of data
      display.print(text); // Print data/text
      display.sdCardSleep(); // Put sd card in sleep mode
      display.display(); // Do a full refresh of display
    sleep(1);
Imam Inkplate 6 i zelio bih snimiti nesto u tekstualnu datoteku na SD karticu odnosno nakon toga procitati tu istu datoteku. Vase primjere za pisanje i citanje sam stavio u jedan te isti Sketch.
Zapisivanje u tekstualnu datoteku prolazi medjutim citanje iste ne prolazi.
Konkretno ovaj dio:
file.open(“/text.txt”, O_RDONLY)
Ako ce pomoci evo i koda:
#error “Wrong board selection for this example, please select e-radionica Inkplate6 or Soldered Inkplate6 in the boards menu.”
#endif
#include “Inkplate.h” //Include Inkplate library to the sketch
#include “SdFat.h” //Include library for SD card
char *fileName = “test.txt”; // The name of a file with the extension.
char *dataToWrite = “Hello! This is the file writing example for Inkplate 6.\n”; // “\n” represents a new line
void setup()
display.println(“SD Card ok! Reading data…”);
display.println(“Error while creating the file!”);
void loop() {
if (!fileRead) {
display.println(“Unable to initialize SD Card!”);
if (!file.open(“/text.txt”, O_RDONLY))
display.println(“File open error”);
display.display();
numOfAttempts++;
fileRead = true;
else
fileRead = true;
char ; // Array where data from SD card is stored (max 200 chars here)
if (len > 200)
len = 200; // If it’s more than 200 bytes (200 chars), limit to max 200 bytes
sleep(1);
Originally submitted via email support on 24 November 2024. Migrated to the forum for community visibility.
First thing I notice is that the path parameter should be const char * type for file.open(). Can you try the examples from our library - sd text read and sd text write - do those work?
If you’re having issues with the SD card, try using the official SD card formatter: SD Memory Card Formatter for Windows/Mac - SD Association - note that this will erase all content on the SD card when used.
If none of that works, can you describe the problem in more detail? Does that line of code return False? Or does it not compile at all?
prva stvar što vidim je da je path inače const char * tip podataka za file.open. Možeš li probati example-ove iz našeg library-a, sd text read i sd text write - rade li.
Ako imaš problema sa SD karticom, probaj koristiti službeni SD card formatter: SD Memory Card Formatter for Windows/Mac - SD Association - naravno, upozorenje, ovo će obrisati sav sadržaj na SD kartici pri kosištenju.
Ako ništa od ovog ne radi, možeš li mi opisati problem detaljnije, ta linija koda vraća False? Ili se ne želi uopće compile-ati?
