Inkplate 6 sketch upload fails with default speed
I received the product but have an issue uploading example sketches. Any advice?
Attachment omitted in migration: PastedGraphic-1.png
Originally submitted via email support on 19 July 2020. Migrated to the forum for community visibility.
Can you please send a screenshot of your Tools menu? Have you switched the on switch to ON position?
When switched on, I get a different error. Here is my Tools menu screenshot.
Attachment omitted in migration: PastedGraphic-6.png
Attachment omitted in migration: PastedGraphic-7.png
Try lowering your upload speed in the Tools menu to 115200. This should help.
Lowering the speed to 115200 worked. The original speed was default. I’m exploring the product now. One question: to use it in a production environment, would it need a better antenna for WiFi? Is that possible?
Great that it’s working now. We have lowered the upload speed in the board definition, so it will always use the lower speed. As for an external WiFi antenna, yes it is possible, but you need to re-solder a small resistor. Do you have equipment to do that?
