Inkplate 6 sunlight visibility and parking terminal application
I’m interested in the Inkplate 6 e-paper display. I’ve previously built similar products sourcing displays from China and creating my own interfaces, but your product appeals to me and would integrate well into my project.
I’m somewhat familiar with e-paper, but I need an honest answer: how does it perform in sunlight? The intended use is in a parking terminal, and I’m concerned about temperature sensitivity. So far I’ve solved this through mechanical design, but I’d prefer to simply install the display and have it work. I also need to ensure product standardization - if I design a terminal with specific dimensions, I need to know the product will remain available in those dimensions for at least 12 months.
Regarding communication: I see you offer multiple options. I’m interested in I2C, SPI, and primarily serial (I see the baud rate is defined as 115200). Are all three options immediately usable without additional modifications? I have my own LAN communicator that distributes communication tasks, and I have free SPI, I2C, and serial channels available. I’m uncertain which to use for the display (serial is prepared, but I might use something else).
The basic functionality makes sense to me - images are called from SD card, which is fine. However, I need clarification on one specific capability that’s important for my application. I’ve easily solved this on my own interface, but I’m wondering how it would work with your display.
I need to send parking fee amounts or notifications as text through communication, and they need to be large and legible. Specifically, how is it implemented so that when I send text, the display knows how to display it according to my requirements and where on the display to position it?
Can you provide a quote for one unit so I can test it?
zanima me ovaj display InkPlate 6 E-paper, dosad sam izrađivao neke svoje verzije sličnog proizvoda gdje bi naručivao iz kine display pa radio svoje interface … Međutim sviđa mi se Vaš proizvod i super bi se uklopio u moj proizvod, a ja se nebih mora mučiti s carinama i glupostima. Da nešto sam upoznat s e-paper, međutim treba mi iskren odgovor kako se to ponaša na suncu? Upotreba bi bila u parkirališnom terminalu i zanima me koliko je temperaturno osjetljiv? Dosad sam to konstrunkcijski rješavao, a volio bih da display jednostavno stavim i to radi… Osim toga htio bih postići standard, jer ako konstrunkcijiski kreiram terminal s određenim dimenzijama da za 12 mjeseci se cijeli dizajn ne promjeni i više mi ne možete isporučiti proizvod u tim dimenzijama… Komunikacija, vidim da su opcije široke, mene zanima I2C,SPI i prvenstveno serial (vidio sam da je baud definiran na 115200). Jesu li sve tri opcije odmah upotrebljive bez dodatnih prilagodbi? Zašto? Imam svoj LAN komunikator koji mi raspoređuje komunikaciju i imam slobodan i SPI i I2c i seral i nisam siguran što bih još koristio za display (pripremljen mi je serial, ali možda bih i korsitio i nešto drugo?). Funkcionalnast mi je u načelu razumljiva jer radi po principu kao i ovi moji što sam ih do sad radio (slike se pozivaju s SD i to je OK). Međutim, zanima me kako je rješena mogućnost za jednu moju primjenu koja mi je bitna. To sam ja lako rješio na svojem interface, ali me zanima kako bi to funkcioniralo s vašim displayom. Ja bih kroz komunikaciju trebao poslati iznos parkirališne naplate ili neku obavjest u tekstuslnom obliku i da to bude dovoljno veliko čitko, (upit se odnosi kako je rješeno da ako pošaljem neki tekst, da display zna kako ga treba prikazati prema mojoj želji i gdje na displayu?). ali javim promjene)
Attachment omitted in migration: unnamed_attachment_1.jpeg
Originally submitted via email support on 5 February 2021. Migrated to the forum for community visibility.
E-paper displays do not perform well in direct sunlight - the image becomes faded under those conditions. This depends on environmental factors, but constant sun exposure is not recommended.
Regarding dimensions, I can say with reasonable confidence that the Inkplate design and dimensions will remain identical for some time to come, though of course no one can guarantee this with 100% certainty.
For communication, you can control it via UART (serial) using its peripheral mode: Inkplate Peripheral Mode — Inkplate docs documentation
The other option is to program it directly, after which you can configure it to work over whatever you prefer, including SPI and I2C. I recommend reviewing the link above for Peripheral mode (also called Slave mode) where everything is documented. This is likely the simplest approach for your needs.
If you have any further questions, we’re available.
hvala Vam na interesu za Inkplate. EPD (Electronic paper display) ne voli jako i izravno sunce jer slika onda blijedi na njemu. Stvarno ovisi o uvjetima, ali ako je konstantno na suncu, ne preporuča se njegovo postavljanje na takvo mjesto. Što se tiče dimenzija, mislim da poprilično sigurno reći da će dizajn i dimenzije Inkplate uređaja ostati identičan još neko vrijeme. Iako, naravno, nitko to ne može reći 100% sigurno. Što se tiče komunikacije, upravljati njime možete putem UART-a (seriala) koristeći njegov peripheral mode: Inkplate Peripheral Mode — Inkplate docs documentation Druga opcija je direktno ga programirati, a onda ga možete naprogramirati da radi preko čeg god želite, uklj i SPI i I2C. Predlažem da si pogledate link iznad za Peripheral mode (ili Slave mode) gdje je sve opisano, to Vam je vjerojatno najjednostavnije za ovo što pitate. Ako imate još pitanja, dostupni smo.
Attachment omitted in migration: Ponuda_br._0057.pdf
