Inkplate 6 touchpads not present on newer PCB version
I received my Inkplate 6 and I’m curious if this version has touchpads. I see them documented but my PCB looks different than what’s in the docs. Am I missing them or are they no longer included?
Originally submitted via email support on 11 December 2023. Migrated to the forum for community visibility.
If your PCB is purple, you likely have the ‘Soldered’ version, which doesn’t have touchpads. If your device had touchpads they would be located right below the ePaper on the front of the PCB. The documentation includes all possibilities so that touchpad models are covered, which is why the photos may be older.
Make sure to use the ‘Soldered Inkplate6’ board definition when uploading code as this likely corresponds to your board version.
