I bought an Inkplate 6 to learn about electronics. After receiving it, I checked the GitHub repository at Inkplate-6-hardware/Schematics, Gerber, BOM/v1.0 at master · SolderedElectronics/Inkplate-6-hardware · GitHub, but the schematic and Gerber files look different from what I received. Looking at the Gerber files, the microcontroller position is different. Is there a different version? Can I get the schematic and Gerber files that match the hardware I received?
Originally submitted via email support on 1 January 2024. Migrated to the forum for community visibility.
Can you check the version number on the back of your PCB, near the corner? Once I know the version, I can send you the corresponding files.
It says 1.2.0. That would be great if you can provide me with the schematic and Gerber files so I can learn electronics better.
Attachment omitted in migration: IMG20240103222433.jpg
Now I can access both the schematic and Gerber files. I have one quick question: do you have a tutorial on how to attach the e-paper display to the PCB, for example using glue?
For attaching the ePaper to the PCB, we use a double-sided tape: TESA-4970-9-50M. It’s placed on the PCB first, then the ePaper is attached to it.
