Inkplate 6COLOR display not connecting, blue LED not working
My Inkplate 6COLOR display has stopped working. The display is ON but I cannot connect to it. The blue LED is not working, which usually lights up.
Originally submitted via email support on 17 February 2024. Migrated to the forum for community visibility.
If the blue LED is not working, there could be a serious issue. First, check if the blue LED switch is toggled on - it’s located on the board.
Also try the power switch.
To help troubleshoot further:
  • Can you upload code to the board?
  • Have you added any components to the board?
  • Have you modified the board in any way?
  • Have you tried a different USB cable or port?
  • Are you using Inkplate 6COLOR with a battery or standalone?
