Hi,
I’m planning to power my Inkplate 6COLOR with the 5000mAh or 10000mAh 3.7V Li-Ion battery from your store (JST-PH 2mm, same connector as the standard 1200mAh option) instead of the bundled 1200mAh battery, to maximize runtime for a wall-mounted HA dashboard that will be hard to access for recharging.
A few questions:
Is the onboard MCP73831 charge current fixed by a resistor value tuned for the 1200mAh battery, or is it safe/appropriate to charge a much larger 5000mAh or 10000mAh cell at that same current?
What is the actual charge current (in mA) set on the Inkplate 6COLOR’s board?
Are there any physical/mechanical constraints (enclosure clearance, connector strain) I should be aware of when using a battery this much larger than the stock one (100 x 60 x 11mm vs the stock battery’s dimensions)?
Thanks in advance!
