I’m using the Inkplate 6FLICK display with a lithium battery and want to implement a function to measure battery capacity using display.readBattery(). Converting voltage to capacity doesn’t seem straightforward. Do you have experience measuring battery capacity this way? Is there a better method?
Originally submitted via email support on 22 April 2025. Migrated to the forum for community visibility.
Battery voltage reaches up to 4.2 when full. Testing shows it’s around 3.2 when the Inkplate display stops refreshing. I recommend setting a low battery alert around 3.6. The relationship isn’t linear, so it’s not perfect, but sufficient to alert the user the device needs charging.
Here’s a function to convert the voltage reading to a battery percentage:
int battVoltageToPercentage(double voltage) {
if (voltage >= 4.2) return 100;
if (voltage <= 3.2) return 0;
// Simple linear approximation
return (int)(((voltage - 3.2) / (4.2 - 3.2)) * 100);
