Inkplate 6PLUS board selection affects GPIO expander compatibility
I’ve tried various troubleshooting approaches but nothing has worked. Would it be easier to discuss this by phone?
Super!
čujemo se može i telefonom ako je lakše - jer svašta nešto sam ja probao ali nije išlo…
Attachment omitted in migration: I2C_scan.png
Attachment omitted in migration: Error_screen.png
Originally submitted via email support on 17 August 2023. Migrated to the forum for community visibility.
Which board did you select in the Arduino IDE - e-radionica.com Inkplate 6PLUS or Soldered Inkplate 6PLUS? This is likely the main issue. The newer Soldered Inkplate uses a different GPIO expander. If you selected the Soldered board, the Inkplate won’t work with it. You need to select the e-radionica.com Inkplate 6PLUS instead. Let us know if you still have problems and we’ll help find a solution.
Možete napisati koju pločicu ste odabrali (e-radionica.com Inkplate 6PLUS ili Soldered Inkplate 6PLUS)?
Mislim da je to glavni problem jer na novom (Soldered) Inkplateu je stavljen drugi GPIO expander te ako je odabran taj board Inkplate neće raditi. Vi trebate odabrati e-radionica.com Inkplate 6PLUS
Ako i dalje bude problema javite se kako bi mogli naći rješenje.
I selected Soldered Inkplate 6PLUS - I have this purple board. I’m compiling for e-radionica now and I’ll report back.
Odabrao sam - Soldered Inkplate 6PLUS - ja imam ovaj ljubičasti - kompajliram za e-radionica pa se javim!
It actually works now! On Linux I got some errors, but I tried it on Windows and the example works. I’ll get back to you if I have more questions. If it’s just an address issue, maybe a new version of the code could have an if statement to detect the address - if it finds 0xblabla you know it’s e-radionica. It’s a bit confusing, but the important thing is it works!
Stvarno radi!
Na linux-u mi izbaci neke greške - ali sada sam probao na windowsima i primjer radi - tnx!
Javim se ako ću imati dodatnih pitanja.
Ako je samo do adrtese onda se možda može i u novi kod napisati neki if - pa da ako ma 0xblabla znate da je e-radionica - ovo je malo zbunjujuće, ali bitno da šljaka!
Good to hear it works. If you have time, you could share what error appears on Linux so we can look into it (no pressure though, we’re here to help if needed). Your board has Soldered markings but uses the MCP GPIO expander. The main difference between the boards is the GPIO expander. If you have an MCP GPIO expander, use the e-radionica board in Arduino IDE. If it’s a PCAL GPIO expander, then it’s the Soldered Inkplate board. Get back to us if you have more questions or anything else isn’t working.
Super da radi. Možete poslati koji error je na Linuxu pa da vidimo što može biti problem (naravno ovo samo ako imate vremena, ako treba tu smo da pomognemo).
Pločica koju Vi imate ima Soldered oznake, ali koristi MCP GPIO expander. Glavna razlika između pločica je upravo GPIO expander. Ako imate MCP GPIO expander koristite e-radionica board u Arduino IDE. Ako je PCAL GPIO expander onda je Soldered Inkplate pločica.
Svakako se javite ako bude dodatnih pitanja ili nešto ne bude radilo.
