Can I connect a USB keyboard directly to the Inkplate 9.7 board, or do I need to use GPIO connections? Also, is it possible to order a modified version using an ESP32 C3 (RISC-V version)?
Originally submitted via email support on 13 August 2022. Migrated to the forum for community visibility.
There are no USB connections available because all the pins are used, and the pins used for the e-paper panel must not be used. The USB on the Inkplate is a USB to UART converter only. The ESP32 C3 cannot be used because it is slower and has fewer pins - not enough to drive the e-paper panel.
